valve lash
Old 07-26-2004, 06:22 PM
palmrose2's Avatar
palmrose2
palmrose2 is offline
valve lash
OK so I know that the proper way to adjust lash is to use different length pushrods. What would happen if I shimmed under the fulcrum if I needed a shorter rod or ground some off of the fulcrum if I needed a longer rod?
Old 07-26-2004, 06:44 PM
mark a.'s Avatar
mark a.
mark a. is offline
You probably could grind them some, but it would have to be done on a surface grinder. You can usualy shim them .03 safely. but you should check the geometry afterwards. It's important that the rocker tip sweep the valve tip evenly or you will have excessive rocker, valve tip, & guide wear.
Old 07-27-2004, 09:17 AM
beartracks's Avatar
beartracks
beartracks is offline
You can get shims from Crane cams to raise the fulcrum. Push rods too if you know the length. In the past you could get push rods from Ford in .030 longer/shorter.
crazy96863
20
05-25-2013 12:28 AM
bradford237
09-26-2012 06:42 PM
the Canadian
12-25-2010 10:10 PM
Steve78
09-04-2006 10:44 PM
turbogus
10-28-2002 11:13 AM
Quick Reply: valve lash
