534 Tune up
Old 05-14-2004, 10:06 AM
rutherj's Avatar
rutherj
rutherj is offline
Question 534 Tune up
I have a 534 in a 1976 Bluebird Wanderlodge. I need points gap/dwell and timing specs. I looked a the previous threads but did not see them posted.
Thanks for any help.
Old 06-02-2004, 08:07 PM
Kenny's Avatar
Kenny
Kenny is offline
Hi,
I'm not sure if they are the same from year to year, but my '59 shop manual shows these settings for the 534 SD.........
Breaker arm spring tension (ounces)......17-20
Contact spacing................................0.014 - 0.016
Dwell contact at idle speed................26 deg. - 28.5 deg.
Initial ignition timing (B.T.D.C.)
With reguar fuel of 85-88 octane.........4 Deg.
With reguar fuel of 88-90 octane.........6 Deg.
With reguar fuel of 90-92 octane.........8 Deg.
With reguar fuel of 92 octane or more, or premium fuel.........10 Deg.
Distributor RPM............................Advance Degrees
400............................................... ......0
600............................................... ......1-2
950............................................... ......5.75-7
1250.............................................. .....9.25 -10.25
1450.............................................. .....10.75 - 12.25
1650.............................................. ......12-13.5
*Maximum advance 13.5 Deg.
Old 06-02-2004, 09:01 PM
rutherj's Avatar
rutherj
rutherj is offline
Thanks Kenny
Old 06-18-2004, 10:33 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I was just checking out other forums, usually I'm in the V10 or FE, but I have a Motor's with the '76 534 in it, and some of the specs are different than what Kenny said.
Here's the poop:
Spark Plug: BRF-31
Plug gap: .030
Point gap: .017
Dwell angle: 24-30
Firing order: 15486372
Timing: Non-Calif: 6 BTDC, Calif: 8 BTDC
Hot idle: 550 RPM
Fuel pump pressure: 5-7 lbs.
That's for 1976
Old 09-24-2004, 10:17 PM
Loan Ranger's Avatar
Loan Ranger
Loan Ranger is offline
If it will help you out any, I posted some tune-up specs in the "gutless 534" thread that may be of some help to you. I just checked and the thread and the post are still there.
In his post, krew said some of his specs showed up differently than what kenny posted. That is somewhat the norm on the older point-type distributors.
If you would get your distibutor tag number--located just below the cap itched in the distributor body and with a 12127 base number--I will be glad to match the tune-up specs with the distributor number for you , if you would like for me to do so.
Old 08-27-2017, 10:57 AM
Dhenry113's Avatar
Dhenry113
Dhenry113 is offline
I recently purchased a 1968 Ford F900 Fire truck with a 534 motor in it. Looking for information on it. Like type of oil to use and so forth. Any help would be great appreciated!
Old 08-27-2017, 10:55 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,632 Likes on 1,331 Posts
Post 4 above is a good reference. As for oil, can you find out what has been used in it? 15w 40 rotella if you can't find out.
Old 09-02-2017, 06:49 AM
Dhenry113's Avatar
Dhenry113
Previous Owner bought the rig and parked it shortly afterwards. Nothing there. Thanks for your reply it did help!
Nolan Harris
401, 477, & 534 SD Engines
29
09-21-2023 09:22 PM
Mrwaynecounty01
Large Truck
10-06-2017 08:25 AM
Jim534
09-01-2017 07:16 PM
Jim534
New Member Introductions
12-09-2016 09:40 AM
Allisfordih
Large Truck
05-29-2016 11:50 AM
Quick Reply: 534 Tune up
