I have a 87 F350 4x4 with a 6,9L and a Borg Warner T19 4 speed. My question is will a T19 from a 460 or engine work behind my Diesel?? I was told that I could only use a T19 that came behind a Diesel, and ones that were behind other engines would not work.
It has a separate Bell housing so not worried about the bolt pattern. Thats why they have the adapator plate so Ford bellhousings will bolt to the Navistar engine
You need a 7.3 bell, and the diesel T19 has a taller 1st gear.
Have you looked at ZFs? They aren't a whole lot more than a four speed and are much more driveable.
I have the Bell housing from my 6.9 I just took the tranny out yesterday it lost bearings and had bad syncro. it had 400,000 miles of hard use on it. they want 1600.00 for 5 speed an only 400.00 for the T19
