EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
3.5 EcoBoost Timing Chain Noise
Old 04-15-2014, 05:44 PM
klasher's Avatar
klasher
klasher is offline
Thumbs down 3.5 EcoBoost Timing Chain Noise
Anyone else having an issue? Marble like noise at start up only. I did an internet search and it said this is a $4,000 dealership fix. I have 92,000miles on it, out of warranty and extended warranty is up. Oil changes done every 5K at dealership where it was purchased. I have an appointment for later in the week, but the YouTube video was the exact sound mine makes.
Old 04-24-2014, 01:31 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Buy a new extended warranty fast!
Also, be sure and use Motorcraft oil filters. Aftermarket filters may have inadequate anti-drainback valves causing less oil pressure at startup. The chain tensioners use oil pressure so that could be the issue.
Old 04-24-2014, 07:39 PM
klasher's Avatar
klasher
klasher is offline
Update: Dealer pulled code. It was not the timing chain it was the left side converter.
Old 04-25-2014, 12:52 AM
cartmanea's Avatar
cartmanea
Converter wouldn't make the noise you described. It's possible the code was unrelated.
Old 07-02-2014, 02:43 AM
rmaratas's Avatar
rmaratas
rmaratas is offline
Im kinda curious about this issue... How did you verify that the noise came from the converter?
Old 07-02-2014, 04:40 AM
EBXLTF150's Avatar
EBXLTF150
EBXLTF150 is offline
Vacuum pump under the driver's side headlight maybe? Others with 2011/2012 reported the same sound and it was a vacuum pump related to brake boost and the device is under the driver side headlight (general area).
But if they dealer replaced one of your catalytic converters and the noise is gone now...ok, maybe something was broke inside.
javi2001
Modular V8 (4.6L, 5.4L)
25
04-12-2020 09:26 PM
craftsmangary
6.2L V8
01-20-2016 12:14 PM
weevensteven
04-01-2012 09:23 PM
ranger730
1983 - 2012 Ranger & B-Series
04-10-2008 02:05 PM
23fnord
12-07-2003 05:24 PM
Quick Reply: 3.5 EcoBoost Timing Chain Noise
