radio, windows, power locks intermittent.
Old 05-25-2011, 07:43 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Sometimes my radio windows and door locks on my 02 Excursion quit for a while till I beat on the dash just over the radio then it comes back on. Any ideas?
Old 05-25-2011, 07:45 PM
dlibson's Avatar
dlibson
dlibson is offline
Many options. But it could be as simple as a ground shorting out at the radio. That can make other things not work. Pull the radio, check the connectors and other wires for obvious signs of shorting or bad connections.
Just cause it's above the radio doesn't mean it's there either. Check the grounds under the cover below the column where the fuses are too. I've seen those come loose before.
Old 05-25-2011, 07:51 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It only happens every once in a while, I thought it may have something to do with my battery randomly draining.
Old 05-25-2011, 08:02 PM
dlibson's Avatar
dlibson
dlibson is offline
Ahhh, more info.
It could. You could have an issue going on with that for sure. Take a look at the wires that go into the door. They can break, short, or get pinched and cause all the above problems. Usually in the drivers door. I had an Explorer that would tell me the rear hatch was open, cruise wouldn't work, rear defrost, and it would randomly beep. Had three broken wires in the bundle going to the door.
Old 05-26-2011, 06:03 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Yeah but why does it all come back on when I beat the dash?
Old 05-26-2011, 06:56 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Could be a problem with the VCM.The brain that runs the interior lights,door ajar,tones,and some other things.Little box mounted behind the radio...IIRC....High dollar little boxes as well.
Old 05-26-2011, 07:45 AM
Calli's Avatar
Calli
Calli is offline
Moisture in the window motors? Also possible leak from windshield behind dash. Trust me, it can cause all the above!!
Old 05-26-2011, 11:20 AM
joeyd61's Avatar
joeyd61
joeyd61 is offline
I have the very same issue... for over a year now....mine doesn't do it all the time,it will go a month no problem,then two times a day..beat on dash, open driverside door count to 5 close door, or just wait and all will work in appx 5 minues...I/ve heard everything from windshild leaking,VCM,bad ground,bad switsh..The only thing i haven't done yet is change the VCM..At this point I just want it to fail so I can find the problem
Old 05-26-2011, 04:37 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I just beat on the dash two or three times and it works. Only does it once in a while, but like you said sometimes it will do it couple times close together.
mrc00l88
12-11-2016 07:33 PM
Oilfan94
07-05-2016 02:32 PM
John Sandru
07-07-2015 10:29 AM
miserableloser
1999 to 2016 Super Duty
10-21-2012 11:25 AM
jc8825
23
08-17-2010 07:04 PM
Quick Reply: radio, windows, power locks intermittent.
