oil temp sensor on 2002 7.3
Old 05-14-2011, 09:07 PM
kenny778's Avatar
kenny778
kenny778 is offline
i am having problems finding someone to help me locate my engine oil temp and sure could use some help
Old 05-14-2011, 09:47 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
The sensor is located on the back of the HPOP reservoir, driver's side.
Old 05-15-2011, 07:40 AM
kenny778's Avatar
kenny778
kenny778 is offline
okay thanks for giving that info . i guess i should have ask about my issue. i changed eingines fromm 2002 w/auto trans. to one from 2001 w/ manual tranny and now i have no fast idle when engine cold and am trying to find problem. this is why i am looking for help.
Old 05-15-2011, 08:07 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 05-15-2011, 08:18 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Did you swap out sensors from old motor to new? One other thing to look at is the air intake señor mounted in the air box, did you leave it unplugged?
Also the engine coolant temp sensor on those two engines is most likey different. That shouldn't effect the high idle, but may cause other issues.
Old 05-16-2011, 07:34 AM
kenny778's Avatar
kenny778
kenny778 is offline
i did swap temp sensors because the plugs were different, also changed complete engine wiring harness. i did plug in cold air sensor but so far still no fast idle when cold. it does start when cold but no hiss or fast idle. when i unplug what i think is cold oil sensor it will not even idle unless i step on pedal a ways.
evergladesgator
11-12-2016 08:58 AM
cory5517
05-25-2016 10:20 PM
billbot
01-02-2016 08:36 PM
Ford are best
05-06-2013 08:16 AM
tneyman
12-15-2010 08:29 AM
Quick Reply: oil temp sensor on 2002 7.3
